Brief Description: front contol stick grip and throttle plate assembl
I include the time for the front stick and grip work with this throttle plate entry but the pics are shown in separate entry.
I applied two more coats of primer on the two strips of throttle plate. You cant see the prop control markings anymore. The second paint strip is just cosmetic and they blend in nicely I think.
reassembled and then drilled a new hole for the single lug plate nut and dimpled and rivited on in place of the vans installed two lug. This allows me to attach the cover surround without interference-just cut a small slit in throttle plate and it slips right in.
other entry today shows pics of stick work
installed single lug plate nut in place of two lug
withe single lug, the cover slips in to groove cut in plate
assembled. The center lever and markings filled in and painrted
