Bill & Brendas RV-8 QB
Date:  5-7-2012
Number of Hours:  6.00
Brief Description:  panel access door-5
Today I sanded all parts and then primered
Dimpled plate nuts and doubler to attach the nuts
Riveted on the plate nuts to the doubler
Countersunk for flush rivits on door and then rivited the hinge to door
Drilled a dozen holes to attach the doubler to bulkhead and then dimpled them as well as the bulkhead
Rivited the doubler to the bulkheadexcept the bottom edge
rivited the bottom hinge half to the spacer and the bulkhead and the doubler
attach the door with the hinge pin
ran a #8-32 tap thru the plate nuts to ease srew insertions
tomorrow ill finish this by cutting a notch in the top part of door so it will clear the baggage door brace
Trial door fit to doubler and hinge
doubler and hinge door rivited
aft side of door
aft side of door
