I dont know why this particular line ( aux pump to firewall line) has been so difficult for me but I think I finally got it. I had purchased an extra 8 feet of 3/8 At for this and used atleast half of it! After 3 iterations using the bender I came up with a nce fit but an ugly over sized install. So I re did it again but by hand and no bender. Came out better but when I flared the 2nd end I had the collar on backwards. 5 try came out fine. I basicly cut a length and flared one end and then attached it. With it attached, I manipulated it to fit and cut off the other end close, made adjustments, removed and flared, reattched and final adjust. Done. Should of done that to start! Gee Whizz!!!
Cutting one piece of many to come
First succesful fit but UGLY
Final hand manipulated line installed. Much better!
