Bill & Brendas RV-8 QB
Date:  10-13-2011
Number of Hours:  0.50
Brief Description:  Fuse Panel and misc.
Today was not very productive plane build wise. Most of the day was spent reorganizing and installing shelves.
Rcd my front and rear throttle quadrants and aluminum air vents from Van's
1. Made cardboard template for a fuse panel to be installed on right side console. Ordered some aluminum sheet since I do not have scrap large enough.
2. ran some 5 conductor shielded wire for the elevator trim tab somewhat where I think I will want it. I plan to order some wire for the tail light/stobe light to run along with itvents
3. Primer painted the two air intake vents
I will make a mount for the ELT and run the wire and then should be ready to rivit on the turtle deck at that point.
Two lever deluxe throttle
Aluminum air vent
Aluminum air vent
cardboard template for fuse panel
