Bill & Brendas RV-8 QB
Date:  8-13-2011
Number of Hours:  0.25
Brief Description:  Fuel tank left side leak test try #2
The last leak test was not successful. I could not find a leak anywhere on the tank by using soap and water but the balloon did deflate over time. So this morning I replaced the balloon with another one and attached to the tank a little different. I also covered the fuel tank gas cap with duct tape. Balloon was inflated by presurizing the tank with air. Coin was traced on ballon as well as a controll balloon at 0730 am. The ballon appears to be staying the same size as a check 12 hours later showed no signs of deflation. Should be able to check the right tank tomorrow.
after 2.5 days. no leaks
