Brief Description: Wire run for wing lights and stall warning
1. Made simple template with a tounge depressor to mark hole location then marked each of the 3 ribs in both wings.
2. Drilled holes to 7/16" with the step drill bit then installed the plastic bushings.
3. Ran one 15 foot shielded 3 conductor 20 awg wire with 1 unshielded 14awg wire from root to tip. The unshielded wire is for the landing light and the shielded is for the strobe/position and sync. This is rt wing. The left wing is same plus an additional 18awg wire for the stall warner.
This should meet all my wire needs for the wings. Hopefully!
Wire run through the lastt rib
Stall warner wiring attached with spade connectors
