Filed edges and then polished smooth with 1 inch scotch brite wheel on die grinder. Scuffed inside skin panel along rivit lines and then primered. Cleaned up edges on two inspection panels, scuff and primed Removed protective blue vinyl from bottom of the finished empenage.
Primered rivit lines inside bottom skin and access plates
