Brief Description: Aileron inbd and obd hinge install
1. Drilled the outboard aileron hinge and attached to the ailerons, match drilled, deburr, and bolt on with AN-3 bolts. Torgue to 30"lb and torgue seal.
2. Did the same thing with the inboard hinge except it has 3 AN-3 bolts instaed of 2.
3. Marked Pitot tube location on bottom skin and ran aluminum tube through wing. Need my flaring tool before proceeding.
4. Made an aileron alignment jig and mounted it to outboard rib on left wing. Ready for mounting aileron.
