Bill & Brendas RV-8 QB
Date:  5-30-2011
Number of Hours:  3.25
Manual Reference:  7-9
Brief Description:  5-30-11 part 2. Flap braces
After preperations of brace edges, The braces are clecoed into position and drilled with botom skin and rear wing spar. Remove and debur holes and counter sink the flange that will have the piano hinge attached later.
Re-cleco the braces and rivit to the wing rear spars left and right. I forgot to dimple the skin before attaching the brace so it was a tight fit getting the squeezer in between the skin and brace flange with out creasing the skin. Using some wedges, was able to get the skin dimpled with out harming anything. Just took longer.
Brace is ready to accept the flap piano hinge when we get set up later. Will do the aileron side and some other things in the meantime
Counter sinking the pianohinge side of the flap brace flange
Riviting the flap brace to spar.
Both left and right flap braces installed
