Bill & Brendas RV-8 QB
Date:  9-22-2014
Number of Hours:  3.00
Brief Description:  emp fairing and gap seal final install fit
Sanded the emp fairing for primer and then sprayed primer on it. Let dry for couple hours and wet sanded.
Fit the underside gap seals so that they terminate in that small gap fwd of the HS and the part of the fairing that wraps around the fwd edge. Its a terrible fit but workd to hide the seal well so im going with it for now.
I countersunk the screw holes in the top lip to the VS and installed screws without the tinnerman washers for now. Trying to decide if I like the looks any better this way.
I also tightened a loose oil line and then filled the oil cooler with some oil and reaatached the line and torqued
Adding oil to the oil cooler
Lower HS gap seals installed
Empenage fairing done
