Brief Description: Stall warner potentiometer for volume control
The warning tone for the stall warner vane is a loud deafing ear piericing noise that I need to turn down some. I decided to do what I had done for the EMS audible warning tones and that the addition of an adjustable potentiometer. I did this the same as I did with the EMS one and that can be refrenced if desired. I drilled a hole in the cross brace next to the EMS poteniometer and installed after soldering some wire leads to the 3 posts on the device and covering with shrink tube. I also added a ring terminal for the grnd wire an dub pins for the other two wires. Installed the potentiometer, attached the ground wire to ground stud near by and then attached the other two wires. I must note that I had to dig out the original wire from the tone generator to the audi panel block and then cut that wire. I then connectorized the ends as well as the leads from the potentiometer and connected and covered in shrink tube. function test successful and the volume level set where I like it. Made sure it was still audible with the radio on and recieving atis information. Made a lable and applied above adjustment knob (not shown in pic)
