Bill & Brendas RV-8 QB
Date:  12-26-2014
Brief Description:  Final weight, balance , and cg sheet done
Finished the weight and balance sheet that I will keep in the plane. I had done several different formats from what EAA has in their packet to the Vans supplied examples. I had decided on the look I wated and with Brendas help, got the data for 6 different load configurations on to a single page. This will be the one I keep with the airplane and the others I had done can be part of the POH or something later.The time I spent with this was rediculous but I think this final copy is fine.
NOTE: The weights have been adjusted to include the batteries for the ELT..I also measure and found slight slight differences in datum for wheels and tail wheel with plane off the scales so ive adjusted them as well and is reflected in final weight and balance information,
