Brief Description: Cowl induction glassing final sanding and primer
I sanded the last application of plain epoxy to the snout inlet extension. Pretty difficult and time consuming because of the small opening. After getting the surface smooth, I primered it. This glass work extends into the cowl towards the Fab aprox 2 inches total with 1/4 inch gap.
I sanded the top cowl lightly and after cleaning away the dust, Primered it with another coat of primer. It should be ready enough now for flying as I domnt see any pin holes. Just need to install the oil dorr now.
Air induction snout glassed extension final sand and paint
