Brief Description: FInish the seal on the FAB, oil and install filter
i HAD GLUED THE TOP SEAL TO THE BOTTOM SEAL ON THE fAB LAST NIGHT AND SO TODAY i DRILLED A HOLE ON EACH SIDE FOR A POP RIVIT. I USED A #4 SCREW WASHER ON THE BACK SIDE OF THE RIVIT TO PREVENT THE RIVIT FROM PULLING THRU THE FABRIC SEAL. tHIS SEEMS TO WORK WELL.
THE K&N AIR FILTER CAME WITH A REDISH TINT TO THE PLEATED FILTER BUT THE RUBBER PART HAS A CAUTUION TO OIL BEFORE INSTALLING. tOO MANY CONFLICTING REPORTS ON DETERMINING IF THIS THING WAS ALREADY OILED OR NOT BEFORE SHIPPING. i DECIDED TO GO TO aUTOzONE AND PURCHASED THE KIT THAT HAS A CLEANER AND A SPRAY ON OIL. oNLY COSTS 12 DOLLARS. sO TO EASE MY MIND, i SIMPLY SPRAYED ON THE OIL AS DIRECTED AND LET SIT FOR 20 MINUTES AND WIPED OFF THE DRIPS FROM THE RUBBER. IT DOESNT LOOK ANY DIFFERENT COLOR WISE BUT AT LEAST I KNOW ITS BEEN DONE. INSTALLED THE FILTER IN THE FAB AND THEN REINSTALLED THE FAB ON THE CARB AS BEFORE.
