Bill & Brendas RV-8 QB
Date:  10-12-2014
Number of Hours:  0.75
Brief Description:  Front baggage door rebuild- the inner skin
My pro seal arrived and so today I mixed it up and applied with a popsicle stick to the inside door rib flanges and then clecoed on the inner skin. I had also prepared the inner skin edges on the scotchbrite wheel.
Clecoed the door in place and then stapped it down good and snug with ratchet straps.
I will let the sealant dry for a few day and then check the fit with starps removed. If all is well, Ill be riviting the inner skin and then installing the door permantly
Glued the fwd baggage door inner skin in place with proseal and then clecoed
Door strapped down in place to let proseal harden and secure the inner skin in place
