Brief Description: Plugs for inside fuse and gather plans and organiz
Pained some plastic plugs from the hardware store that are used to plug PVC pipe. They happen to fit the lightning holes in fuse perfectly and when installed will hide the wires behind and such. The lightning holes for the rear and front throttle will wait until after inspection as they are tight and a bit difficult to remove without scrathing things. Brenda found these plugs at the hardware store after a sales person suggested them. Sweet!
Installed the lower cowl so I could leasure for the snorkel fabric and then positioned the top cowl for inspiration.
Plugs from hardware store painted and snapped in to hide wires behind
