Brief Description: Applied straight epoxy mix to the empenage fairing
The emp fairing is full of pin holes. Discovered after applying sanding primer. So I brushed on a coat of epoxy today. Will sand tomorrow and see if that helped any. I wanted to use acetone to cut the epoxy but all I had were foam brushes to apply with.
