Bill & Brendas RV-8 QB
Date:  8-8-2014
Brief Description:  Wired up right side landing light and nav/strobe l
First the Landing light wiring. The landing light is HID and has a ballast thing that chages up enough oomph to ignite it. The wiring had an issue however and I finaly isolated the problem to a poor connection at the pin crimp in the weather proof body. I had to push out the pin and solder the conection and then reassemble. Tested it and it was fine. I then cut the wires to length and used shrink tube and snake skin as required. Crimp on the connectors for the supply wire from switch panel and then routed and secured to wing rib
I did the nav light and strobe pretty much the same as left wing. see yesterdays post
Put protective spiral wrap anywhere the wires could vibrate against a metal edge.
HID lnd light wire plug rebuilt
LND light wiring installed
Right NAV/strobe connectorized and secured.
