Brief Description: Connect taxi light and position light and strobes
removed taxi light and installed the 100 watt bulb and tested tthat it works. Made a ground wire and attached to the lug on light housing and the other end to the rib Attached the pwr wire after installing female spade connector and shrink tube etc and attached Secured the wire to the floor of wing with sticky connector base and zip tie and then again to the lrib with a plastic wire holder
The 3 wire shieled bundle for the nav/strobe lights was prepped and connected with the molex female pins and then inserted into plastic body in the correct order to math those from the light. Added a ground wire and pin for the molex to match the ground from the light side and then drilled a hole in the rib to terminate it.
The shield wire was connectorized as well an also secured to the rib
Spiral wrap added along wires where they could possibly rub an edge of metal
Taxi light 100 watt bulb installed. Note the sticker on the back.
Nav/strobe light wires from switch and wing connected and grounded
