Bill & Brendas RV-8 QB
Date:  7-13-2014
Number of Hours:  1.00
Brief Description:  Alter rear stick grip for better clearence
My stick grips have a nice bottom lip to rest your hand on. It hits the seat in rear however. I decided to remove the stick and cut half of the lip off and then smooth out on scotch brite wheel.
I didnt know that gaps between two molds would be revealed in doing this. Soooo, now I need to mix epoxy with black pigment and fill in and work the edge some. The operation wasnt even a success. It still hits the seat cushion though not as bad. Guess Ill be calling flight line interiors to see if I cab have the bottom cushion redone.
Hooked the front stick back up and it does not seem to have an issue with the front seat. I need to get the wings on and attach ailerons before knowing if the front seat will require any alteration. more on this later.
Cut some of lip off rear stick for clearence
