Brief Description: mask and primer the left canopy skirt
Fter sanding the aft inside edges for a looser fit when closing i masked the canopy off on the left side and applied 2 coats of sanding primer. Looks terrible but at least it isnt pink anymore! I decided to not spray the other side and try brusing on epoxy with acetone mixture to see if that does any better. I will probably sand most of the primer off and the brush on epoxy,
