Brief Description: covered the unneeded scat tube flange in aft baffl
Not to rant about this again but the baffle kit was not updated to reflect a change in heat muff and heat muff location. How is a builder to even know ther was a change if there isnt a note anywhere? Anyway, the hole in the right aft baffle is not needed because heat muff moved from rt side of engine to under the front end of engine and the air intake for it needs to come from the left lower intake ramp. I realized that I was supplied with a cover that can be used to cover the heat muff out put flange to the FAB if carb heat is not desired. Since I am setting up carb heat, I decided to use this cover to seal off the Unneeded hole. This is nice because I can remove cover if I decide to use the air port for something else some day.
Fit the cover and drilled the 3 mounting holes and rivited in place with some simple pop rivits. Sealed the edge around cover with sealant.
