Brief Description: upper intake cowl ramps epoxy1 and 2
The upper inlet cowl ramps were epoxied in a while back and with left over epoxy slurry from the windscren fairing, I had applied to the edges of the ramp where it meets cowl skin. When the slurry was dry, I spent an hour sanding the fillets down to a feathered edge just on the right side ramp. I then applied a big dab of thick microand cotton mix to the radius areas to make a nicer transition. This isnt necessary but it will look better if anyone is inspecting the work or if the cowling is off. Not sure its worth the time but.... I still have the left side to sand down later
Sanded off extra epoxy to upper ramp to a feather edge
FFwd edge of upper intake ramp feathered in
Applied a thick fillet in the radius of both ramps
