Brief Description: rt side baffle tension rods finished and installed
I already had previously cut to length the tension rods so today I worked on getting the bends and or joggles in them so that they would fit without rubbing against anything. I also threaded them to 6-32 and cut off excess rod. Installed the steel lock nuts and tightened up. Ill get to the other two after I put the left front baffle back on
post 3/3 today.
Put necessary bends in the rt ibd ension rod and threaded
Rt side obd tension rod joggle around an oil return line
