Removed 3 bolts from the top engine case and installed the aft and fwd center baffle brackets and re torqued the hardware to 96 inch lbs
Fabricated a spacer from AT6-058X3/8 7/8 long for the left aft baffle and then started to fit that baffle into place. It doesnt fit and not sure why at this point so I will need to try again some other time
