A friend came by and made a casting of the left and right sides of cowling with plaster for cover plates that I will use to cover the hinge pins. I then tried going thru each eyelet on the hinges to clean any epoxy residue with knife to remove any epoxy residue that could be causing a fit issue and making the pin extremly difficult to install and remove. This seemed to help considerably in the left side but very little to nothing on the right side. Ill be working this more in the future.
