Bill & Brendas RV-8 QB
RV-8
Drill the right upper cowl hinge. Nose nut plates
1. Counter sink 12 rivit holes in the inside nose area of cowling for the three K1000-8 nut plates.
Installed the nut plates with an426ad3-4 rivits.
2 Measued distance from top of bottom cowl edge to the middle of the upper hinge half and then installed the upper cowl again.
3. Transfered the upper hinge mid point tot he upper cowl. Marked where the rivit holes need to be. Centerpunched and drilled each to #40 and cleco.
4. Drilled exit hole in outside cowl in nose for the hinge pin to exit.
Pin secure method is undecided at this point.
K1000-8 nutplates installed on bottom cowl. Top secured to bottom with truss screws
Right side cowl horizontal hinge all drilled up
Cowl halves hinge pin exit hole drilled
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
