Removed engine from box with hoist. Instructions say to lift out of box vertically but that didnt happen. I removed staples on box and pulled sides down and cut off. I then had to pull some of the foam away until it freed the engine up. Slid the table out from underneath and the box fell away. The engine was not attached to a crate or anything in the box and so it needs to sit on something fairly soft until its ready for mounting. I didnt have any car tires but I found that the foam top from box worked. I laid a board on the crane legs and with the foam on it, simply lowered the engine on to it. I can keep some tension on the lift as well while I prep it for install. Im leaving the bag on and covered hole with tape. I will probably start install prep work in couple of days
Time spent on this also includes some research on the upcoming tasks.
