Brief Description: Re position pitot tube penetration and misc.
I first took the front foot wells out and re drilled where the pitot line needs to go without interfering with the foot well. I ended up reinstalling the foot wells several times before i was done with it. Pitot tube now is cleanly run. I will need a 9/16 plug for the now vacant hole however. No biggie!
I then removed protective tape around edges of my switch console and screwed it in with #8 screws. I did use protective nylon washers to protect my fancy primer paint job!! Ha
I also installed the over sized washer I made yesterday from aluminum bar stock to the back of the gascolator on the left bolt since it didnt have a reinforcement as the right did.
Clecoed in the rest of the front seat ramp and reinstalled the front seat back rest for asthetics and then vaccumed out the interior.
Safe air bulkhead connector repositioned for pitot tube
