Connected the wire from wing sensor to the 3rd lug Ran a 22 awg wire from the 4th terminal to the intercom terminal block
Made a big tail from the intercom audio in to sapre block and connected. This will allow me to hook up additional audio signals from the stallwarner as well as the audio from the EMS warnings and the GPS
Fab and run 18awg wire from the 2nd lug for ground to grounding stud in brace. I spent considerable time removing the old grounding screw and replacing with a longer one that will allow for additional connections. Was difficult to get to with all the wire in the way now,
I used a inline fuse assembly with 2 amp fuse to attach this gizzmo to power. This comes out of the 1st terminal and goes to the flap power stud.I elected to use that point because my instrument power point is getting full and the flap has its own 5 amp fuse and is powered up when master is on. Seems perfect!
