Brief Description: Fuel selector position plate installed
Drilled and countersunk for #6 screw after making sure I had the pllate oriented correctly on the valve. Coluld accidentally install 90 to 180 out and have selector pointing to off when actually on etc. I spent some time blowing air thru the left and right lines to valve to verify the open positions and then oriented the plate to line up with selector nicely before marking. Instaled stainless steel cs screw and nylock nut and washer on reverse
