Brief Description: tru trak auto pilot master switch install and wire
Wired the trutrak auto pilot backlight/dimmer up and connected
Drilled a hole in right lower console for a master switch for The auto pilot and installed the switch
wired the switch to a 2 slot mini molex conector body
ran wire from the instrument power post thru a inline fuse with 5 amp installed down to the molex connector and back to the control head from the switch.
auto pilot master switch added next to the wig wag switch
molex mini connector added under lower rt console for easy removal of cover
5 amp in line fuse added from intrument power post to the switch
