Brief Description: Front airvent reducer installed
Removed the aluminum airvent because I forgot to fit and install the plastic reducer that goes behind it. Located the vent reducer and clamped it to the eyeball vent, match drilled it with step drill applied weather strip adhesive to the two pieces and pressed togeteher. Reinstalled in the panel
match drilling the plastic reducer to the eyeball vent
