Bill & Brendas RV-8 QB
RV-8
pressure manifold drilled for install
measued for mounting holes for pressure manifold as per dwgs and then drilled and mounted with hardware called out.
Installed two supporting adel clamps for the oil pressure line on the firewall from the manifold
drill 3/16 holes in fire wall to mount the pressure manifold
pressure manifold mounted on firewall
installed two adel cushion clamps to hold the oil pressure line from the manifold
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
