Brief Description: final pitot static tube runs and attacment
I had ordered a bulkhead fitting for the pitot tube wing to cabin transition and also a y connector to finish static sytem. changed a couple of fittings on the back of gages cut some better lengths of static tube on manifold used the red colored tube from pitot tube to use from ASI to the bulkhead fitting in wing root drilled 9/16 hole with unibit for the bulhead fitiing for piutot tube drilled a hole in left gear tower for the pitot tube ran the pitot tube from bulkhead fitting to the ASI tightened up all pitot static fittings red loc tight to nuts on bulkhead fitting and covered out board port with tape
red pitot line from wing bulkhead fitting to ASI t fitting and on to Auto pilot with clear tube
hole drilled in left gear tower to accomodate the pitot tube
Pitot tube from ASI terminates at the bulkhead fitting in wing root area under left console
