Bill & Brendas RV-8 QB
Date:  9-10-2013
Number of Hours:  0.75
Manual Reference:  ACS and op10
Brief Description:  ACS ignition wired
Between the wire diagram from op10 and the switch markings and the ACS intruction, I was able to wire up the ignition switch. I have some confusion on the left mag connection at this time so I left the bridge unconnected untill I find out. If its needed, I casn simply swing the bridge over and secure to the other lug.
Applied some dielectric grease to the connections and zip tied and covered with spiral wrap.
Probably could use an adel clamp on cross brace or gear tower.
Final connection fo the starter relay diode
ACS ignition wiring
ACS ignition wiring
