Brief Description: D Sub pin to trim indicator wires and misc wire wo
Strip 18 wires for trim indicators and crimp on d sub pin. Also did the wires from the servo with appropriate pins
Ran an 18awg wire from behind panel to the left fuse exit hole where the light wires exit. This wire is for the connection to the stall warner. Labled the ends for identification later.
