Sanded the epoxy cabosil mix applied yesterday to the top and bottom caps. Attached the rudder to the VS to check for hight variation from VS tip to rudder tip. The Rudder tip is now taller. So I just traced a line around the VS to the Rudder, removed rudder and had Brenda try her skills at sanding it down to the line.
