Brief Description: Fiberglass tips sanding prep and primer
1. Spent 2.25 hours sanding the empenage tips (except for the rudder bottom cap). I will try and finish up the HS, elevators, VS tips before getting back to the rudder tip and bottom cap.
2. Masked of tips and sprayed the tips with sandable grey primer from Autozone. The tips look suprisingly nice and after light sanding and a touch of super fill here and there, might be acceptable to call ready for a primer coat.
Sanded HS bottom side tips
sandable primer to HS tips
Elevator tips sanded and then applied sandable primer filler
