Brief Description: firewall battery ground and misc
Drilled a 5/16 hole in firewall location specified in vans fwf wiring drwg. The bolt used was from B and C and is a brass bolt. I like it better than what Vans calls for. Besides, They did not send waht they call for. Surprised? No!
I then attached the supplied cables and boot but left loose. The Wire fro battery ground to stud barely makes it and I think I might need to remove part of the battery top that is used for a carry hold. Its just a bit fo rased plastic and not structural to battery and vans says its ok too. I also had to drill open just slightly the conectors on these cables for the 5016 bolt.
I cut, measured and drilled two #6 screw holes in copper bar to connect my two 10 amp circuit breakers for pilot cigarrette 12v plug and a wig wag flasher unit. I dont like how close I put them to the devices they will operate but if I need to cahnge later, Ill just put an inline fuse further up stream and remove the CB's.
Not pictured is the wig wag flasher unut. I drilled and dimpled for 2 number six attaching screws and attached to the rt lower pilot console with the wig wag switch and cig adapter.
Battery grounding stud to firewall
Battery ground wire and engine block ground wire to stud
