Brief Description: Drill wire thru holes in floor and temp install fl
Drilled a hole in footwell flange for the flap weire and grommet and slotted the edge so it can be removed as needed. Did the same with the aft floor rt side.
Tightened the 3 seatbelt anchor bolts on each side in rear baggage and clecoed in the baggage floor
Cleco in the aft floor and foot well and then installeed the seat backs with hinge pins.
