Finished up the flap switch wiring today. I drilled and installed a plastic snap bushing to bring wires from flap motor up from the floor on aft side of left center bulkhead. I attached the wires to the bulkhead with adel clamp and ran wires thru the access hole and then accross to the throttle quadrant and my flap switch. Crimp on the ring terminals and some shrink tube and attached them to the center lugs on the switch. The power and ground wires from the switch move forward using the propeller lever cable hole since I wont be using it and then up to the power dist bar and ground point. I labeled the wires and conectorized and attached to the power. Tested operation with lawn mower battery. Checks good.
Flap motor wires coming up the left center bulk head from floor
The flap motor wires thru the bulkhead and connected to the switch lever
Flap power wires labled and positioned at power lpost
