Brief Description: Install the stereo input jack, run the wire
In order to instal the stereo input jack, I first needed to decide on convienient location.The panel is suggested but I didnt want the ipod wire hanging down from it so decided on the right side center bulkhead. There was aleady a hole in an out of the way spot and only required slight up drill to 1/4 inch. I did that with a unibit and then installed the jack. Nice thing about this location is that I can access the back of it if I need to through the access plate I fabricated for my map lifght.
Located the wires in the bundle for this jack and since they are not long enough, I had to cut to short lengths of 22awg to reach with some slack. This was my first solder so I snaped a pic. I then covered with shrink tube. I drilled the hole on fwd side of bulkhead for a snap bushing. Did the same in the gear tower top outboard aft side where again there was already a hole that only required slight enlarging. I ran the two wires through the bushings to the jack and tied with lacing cord. Ill solder to the plug next time.
I started gearing up to solder the wires to the headphone jacks for the GIB. I cut the 4 conductor insulted wire down to length with service loop. I then cut back the outer cover to the shield. Poked hole in shield and pulled the 4 conductors thru and then twisted the shield. I stopped here because I need to find out what needs to be done with the shield on the jack end.
Another issue I have is the wireing for the mono/stereo switch. Instructions are not real clear on this. I only think I know how it is to be wired. Im debating on taking the switch out and plugging the hole with plastic cap since I dont need the switch any way.
Spent good deal of time studying the wire diagrams to only slight enlightenment. That time was not recorded.
Stereo input jack on aft right upper center bulkhead
Butspliced extra lenght of 22 awg wire to the harness stereo wire
