Brief Description: Attach wires to the switch breakers in console
!. Removed the master switch from console to attach the wire ends to it. Two of the inside terminals are not accessable when installed next to the other breaker. 2. Fabricated a short length of 18awg wire with tounge terminals and attached it to one of the master switch terminals and the other end to the alt.line switch. 3. Attached the remaining wires per dwg op10 and op11
4. Continuity checks made on all wires attached 5. master switch reinstalled after some slack was provided after cutting some zip ties. Ill reinstall the zip ties later.
I plan to clean up the wires under console and tie them together for cleaner look.
