Brief Description: install main wire harness into position
Sorted out the big wire harness mess by putting painters tape on groups of wires that go to the same place. I then set out to route the wires through the towers and then to their respective homes. It took much longer than I thought it would too! I now have groups of wires at the console for switch breakers, at the cross brace terminal power distribution. I have the wires run for both wing nav lights, the flaps and the boost pump. I have the wires ready to run thru the baggage wall and then thru th firewall to the battery but I still need to figure out where to drill the holes first. The wire harness does not have wireing for the landing and taxi lights but I have that in the wing already anyway but I will need to run wire from the power block for them with a disconnect at wing root or something. Lots to do on this yet!
Wires ready for switch breaker console
some wires for the power distribution block. Wires for ignition lower rt corner
