Brief Description: Fabricate the fuse block and drill to fwd brace
Fabricated the fuse block that mounts to the fwd brace with supplied materials. I dont have the correct length of screws so I will need to order some but in the mean time I used shorter # 8 screws for setting it up. The top half was measured and marked for the 7 studs aprox 1.5 inches apart. I set up a bit stop so that it would drill thru top and only 1/8 inch into bottom. I then separated the halves and final drilled to #19. The bottom half needs to be bored out to 1/8 inch depth and diameter wide enough for the screw head. Placed the halves together and marked the three mounting holes and drilled them all the way through. I then marked a center line on the fwd brace left side, Placed this bllock on the brace and centered over the center line drawn. I transfered the holes to the brace with a center punch and then drilled and clecoed on to ensure proper fit. Ill mount permantly once I have the proper hardware.
Top fuse block half with screws and bottom half bored to cover screw heads
both halves of fuse block together so mounting holes can be drilled
Bottom half mounting holes transfered to the fwd brace an clecoed
