1. I spent too much time on this. Even called Vans only to be asked to take a pic and send it to them. The photo below is pic of drawing showing the heat selector box on same side as battery. But,,,,,,The quick build fuse came with it pre cut out on the other side! So, Im trying to figure out if this will be a problem or not. I will have a gascolator mounted just below the pre cut out area and dont know if that will be an issue. I think I should go with it as pre cut and if an issue comes up, Ill cover hole and drill a new one beneath the battery as shown in drawing.
Drawing showing the fw mounted battery and heat select box on starboard side
