Brief Description: rear map light switch/ inventory of FW fwd kit con
Brenda finished up the firewall forward inventory of the hardware bags and then stowed in bins and labled. We will need to pick up another storage bin at harbour freight tomorrow.
I decided to install the rear maplight switch on right side in close proximity to the light (see photo for location). Marked where I wanted the hole and drilled to 1/4 inch. I then maked and drilled a 5/64 key hole for the keyed washer that prevents the switch from rotating. Deburred and then installed untill Im ready to wire it to the light later
