Brief Description: panel radio tray bracket rear support -2
1. Installed temporary the end plates that hold the d sub connectors and coax cables to the end of radio and transponder trays.
2. Fabricate the other L bracket for rt side of transponde trayr and installed with clecos. Holes were drilled to accomodate #6 screws
3. Fabricated the L bracket to support the end of radio tray. Drilled it to the end plate and to the fwd upper brace. The wire harness and coax will plug into the left side and so there shouldnt be any interference with the bracket. I could install a second one on the other side but I dont think its really needed.
4. Clean, scuff, clean, primer the aft baggage bulkhead panel. I hadent done that yet so decided to do it. I will rivit on the clips tomorrow.
End plates temp installed on the radio trays
Rt side bracket fab and install on xpr
Btacket fab and install on radio tray rear bracket to fwd brace
