Brief Description: Fab brackets to secure back of xpr tray to airfram
1. After thinking it over, I decided to brace the transponder tray with two brackets that will attach to the tower brace forward of the panel. I cut two lengths of 3/4 X 1/8" flat Alum bar, bent aprox 90 degrees. Marked center and then marked the hole location thru the radio tray. Drilled the brackets for 2 mounting screws.
2. Pondered and finaly decided on how I will secure theback of the radio tray. I will hopefuly finish that up tomorrow.
3. Located the installation booklets to get an idea of what needs to be done for attaching the wire connectors to the trays. This is very unfamiliar territory!
